j_murrayExplorerDec 28, 2013brake lite switch with air brakesI need to install a brake controller in my dp but cannot find the brake lite switch. Any other tips would be helpful. It is a 2006 Mandalay Presidio Thanks for any help
ScottGNomadDec 28, 2013If the brake and turn signal lamps are the same bulb then you may be able to get to the brake light signal at the turn signal control.
Related ContentSurge or electric brakesSwitching toiletsBrake Buddy Brake away switchAutimatic Transfer Switch?Brakes grabbing
