DSDP_Don
Dec 28, 2013Explorer
DP's don't have brake light switches like you may be use to. You'll have to track your wiring down and find a place where you can tap into it. You'll often find the wiring you need near where your Allison computer, engine computer and other electrical is centrally located.
Usually there will be something marked in this area for brakes. Put a volt meter on it and see if you get 12 volts when the brake pedal is depressed with the ignition key ON.
38,777 PostsLatest Activity: Jun 28, 2025
