jtfcons
Jun 05, 2014Explorer
The usual reason for the problem is that it was parked with some moisture left in the drums as in after a rain shower, etc.
To prevent the sticking, although this is hard to remember to do at the time it happens, is to apply the brakes lightly as you park it. This is enough to heat up the drums and evaporate the moisture.
If you forget to do the above, as I have, rather than just putting it in gear and breaking it loose, try gently applying forward and reverse to break it loose.
