RLS7201
Nov 05, 2018Explorer II
I don't think the heat affects the pads much. It's the heat boiling the brake fluid that's a problem on our F53s.
My 95 F53 don't stop well when the brakes are at ambient temperature, they need to warm up a little for best braking.
You may want to consider DOT 5.1 brake fluid. I believe it has a higher boiling point than DOT 4.
Also, check the outer brake pad fit in the caliper mounting bracket before you secure it to the caliper. I find most pads are a touch too long and don't float well in the bracket. It needs to float to release properly.
Richard
Richard
