zephyrprime's avatar
zephyrprime
Brake parts for 1994 winnie minnie
Hello all. I have just picked up a 94 winnie minnie WF528RQ. The breaks are soft and also they pulsate when I apply them strongly which indicated warped rotors. A cursory examination of the front rotors indicates they are probably worn below minimum rec thickness.
Now, how do I find the right parts to replace the rotors and pads? Does it have the same front and rear brake system as a Ford E-150 van which I believe it is based on (correct me if I am wrong)? Does it have disc or drum brakes on the rear?
I have been to many car part sites and none of them have info for a winnebago. I also go the parts manual from winnebago but it doesn't list any vehicular parts.
  • You need to identify what chassis you have. It could be GM or Ford.
  • DrewE's avatar
    DrewE
    Explorer III
    A 1994 is most likely an E350 chassis; I think the E-SuperDuty (which was renamed to be the E450) was not introduced until a few years later. There probably is badging on the side of the cab to identify what it is--or you can check the VIN, data plate, etc. to figure things out.
  • You have to look up the parts as a Ford.
    Rock Auto has everything you need.
    The Cab and Chassis vans use different brakes than the E150.
    If you can post the VIN#, we can tell if it's an E450 or E350.
