sealevel_ram's avatar
sealevel_ram
Brake Pro Will Not Shut Off
I have used a Brake Pro supplemental braking system for several years.
Now when I plug it in, it will not shut off. The pressure builds up, and it will deploy when I push the test button. But it still runs.
Moving the sensitivity buttons does nothing.
Anybody have this problem, and know a solution? Or is it time to move on to another brand?
  • x2 on tommy g suggestion system is losing air could be a loose fitting or hose inside. If your handy you can pull the cover and check these items yourself. Just be careful not to cycle it with the arm not secured to the brake pedal. If your not comfortable working on this as suggested send it in for repair.
  • Your pressure system probably has a leak. My Brake Buddy came on often enough to run the battery down so I sent it in for some overdue repairs. It has been fine since then.
