snooper wrote:
I doubt if they took the brake pads out.... most likely "eye balled" the pads... I had this happen to me several years ago... I pulled into a camp ground with a older MH and had a brake pedal problem... I discovered one of my front wheels was hot,after cooling, the brake pedal worked great. No problems with my return trip home. .... next outing, after traveling about 5 miles in town traffic and using my brakes several times, the pedal went to the floor... the wheel was hot... took MH to brake shop and discovered caliper was not releasing all the way and was dragging the disc pad on the disk..overheated the caliper & brake fluid.... changed out the calipers and no other problems... Just giving you my expereience...
X2
Same thing for me. This occurred after I slammed on the brakes to avoid two guys on bikes.
Slide pins needed cleaning and grease, otherwise brake shoes dragged, built up heat, little to no brakes.
