Mile-High-Endur's avatar
Apr 27, 2016
Brakes on C5500 Kodiak
Has anyone replaced their Kodiak's brakes? I've noticed a grinding noise from the front brakes lately. There is alot of pad still there at least 3/8ths of an inch. Also the pedal is feeling soft. I plan to get them checked soon. Just bracing myself for the cost. LOL. Thanks.
Jeff :)
  • Come to find out the rear calipers were stuck and wore off the outside of the rotors nearly to the vents in the center of the rotor. It appears that because of the weight of these rigs there is a lot of brake bias to the rear brakes. Not like a regular car or truck where the front brakes do the majority of the braking. So I got new calipers, rotors, pads and seals on the rear and the fronts are still good. It is difficult to see the rotor the way everything is covered. You need to pull the wheels to get a good look.
    Jeff :)
  • Thanks Ron. I'm taking it in on Monday to get looked at. Will let you know what happens.
    Jeff :)
  • You may have picked up a stone.
    Here is some info.
    Brake job '06 5500 13.5klb rear axle
    While your MH is not at diesel. The brake systems and parts are the same.
    There is other info on DP for Medium Duty Truck brakes. Do a advanced search in that forum only.
