Daveinet
Oct 04, 2013Explorer
The question is how hard is it to push the pistons back into the caliper. If they push in fairly easy. Normally it does require putting a C-clamp on them, to force them back into the caliper, but it should be fairly easy to turn the c-clamp. Basically you should almost be able to push them in my hand. If it is tighter than that, then the piston is binding and the calipers need replaced.
38,780 PostsLatest Activity: Aug 05, 2026
