bluebarry1964b
Oct 06, 2013Explorer
randallb wrote:
blue,
You do not have to anything you do not want to. Neither does the repair shop. He recommended caliper replacement and now the decision is yours. He is the one that writes the check for the liability insurance each month and understands what heat does to brake components. If you decided not to replace the calipers, one of them fails and something catastrophic happens you are not going to sue yourself. You will blame the repair facility or an attorney will convince you that someone other than you, or your insurance, needs to pay for the injuries and/or deaths that occurred. Since the shop has already recommended the replacement any deviation from this recommendation will turn in to an admission of guilt in a court case. The judge or jury will come to the simple conclusion that the repair facility should have known better. After all they were the professionals receiving compensation for their services.
Every shop owner out there has lost at least one small claims court case to this reasoning if he has been in business for any length of time. It all comes down to liability and if you want it done your way then do the work yourself and assume the liability for your decisions.
Randy
That's not really the situation:
1) There is no shop involved. A retired heavy duty mechanic at the RV Park is the one looking at doing the work.
2) He did NOT recommend replacing the calipers. He figures that just lubricating the pins with anti-seize lube will do the trick. I'm the one who's wondering if the calipers shouldn't be changed at the same time.
3) As far as me blaming the repair facility in the event of an accident, I find that statement highly offensive. Perhaps it would be better if you actually knew me before assuming that I'm the type who would do that. Not all people are built with the kind of mentality that goes around blaming other people when we, ourselves, are to blame.
Having grown up in Canada, our culture is Completely different when it comes to involving lawyers in things. For us, lawsuits are generally frowned upon except in extreme circumstances. We see lawsuits as kind of an immoral thing to do. Often, even in the event that a lawsuit is completely justified, we don't go that route. My father was run over & killed some years ago & I'm sure that I would have had good grounds for a lawsuit, but that's just not how things are done. Lawyers don't "talk us" into anything.
38,782 PostsLatest Activity: Sep 10, 2026
