rgatijnet1
Dec 12, 2015Explorer III
If I read it right you get less and less brake pedal travel, which is the opposite of what would happen if your brake fluid boils. Dragging brakes usually causes the fluid to boil and the pedal go to the floor. I would guess that your problem is caused by too much pressure being developed in the master cylinder that prevents the pedal from being pushed down.
