Rickieblue
Dec 12, 2015Explorer
Another possibility is that the brake lines were put on the master wrong as the rear brakes have a residual valve which holds 10 to 15 psi in the system whereby the springs on the rear shoes require more than 15 psi to activate but the front will drag pretty heavy with 10 or 15 psi in the system. Also the master could have had the residual valve put in the wrong outlet too!! Just another option to look at.
38,782 PostsLatest Activity: Sep 10, 2026
