rgatijnet1
Dec 13, 2015Explorer III
donfrump wrote:sjholt wrote:
I think the problem may be in the brake crossbar binding up and not releasing the brake. That happened to my 86 P-30.
I drilled a 1/8 in hole in it and stuck a zerk in it and pumped it full of grease. End of problem.
Worth looking at.
Are you talking about the brake peddle assembly?
There was a problem with that happening on some early WH "W" chassis models to lubricate the bellcrank. You just drilled a hole and added the zerk. I was not aware of that being a problem on the "P" chassis.
38,782 PostsLatest Activity: Sep 10, 2026
