tropical36
Jun 16, 2015Explorer II
lovervn2 wrote:
I have the ready brake system with my Class A Sightseer 34' and Toyota 4Runner automatic with drive shaft disconnect. I am having one heck of a hard time getting it to work properly. It appears the brakes on the Toyota are not releasing. I have talked to the mfg. and they haven't been a lot of help. Said I needed the anti rattlers cuz there was too much play. That didn't work at all. I'm about ready to thro it in the ocean it has been such a hassle! Do you have any suggestions? The only thing that I wonder about is the break cable is not going down the middle thr the release lever on the top of to bar. Any help greatly appreciated!
First I've heard of this with a READYBRAKE, so who installed the thing?
I've even heard of a would be professional who installed the optional READYSTOP breakaway for use as the braking system. Now that would lock up the toad brakes, big time and exactly what happened.
Whatever the case, I can assure you, that something is very simply, bad wrong here and you might find another setup for looking it over.
Assuming all else is correct and with this talking about being centered, the cable obviously needs to be mounted dead center on the front of the toad and if not, should be moved to that point. Mine is right under the bumper and lines up perfectly both top to bottom and left to right.
