darsben
Sep 23, 2014Explorer II
dkmthecook wrote:
I have checked the tires pretty thoroughly and there is no sign of dry rot or anything else. I am somewhat of a gearhead and I tried to check out everything I could before I bought it. The 350 motor is in good shape and since it does have 63000 miles on it I figure it is pretty well worn in. A 350 is an easy motor to work on and that was one of my prerequisites since I will be doing all the work on this myself.
How did you check out the tires?
How old are they? TO be properly checked out RV tires need to be inspected if over 5 years old. The problem is sitting in the sun uncovered the chemicals in tires evaporate and this weakens the sidewall, this can lead to unexpected blowout. SOOOO, please find the DOT date code and find out how old your tires are.
Unlike a car Just because there is plenty of tread it does not mean that the tires are good. A blowout can easily cause a thousand dollars damage (experience of mine). Please do not take this lightly
