Cheryl_B
Jul 02, 2016Explorer
What I'm saying is this can't be a pump problem. This is what happened with the pump I just replaced. The symptoms are the same. Help me to find the problem either up or down stream from the pump. Where are water filters generally found? How can you get to the back of the fresh water tank when there's like an inch or maybe 2 to work with?
Ideas. I need ideas. It's not the pump. I'm pretty sure the old pump was fine, but started to leak because I didn't find the real issue.
