Cheryl_B
Jul 02, 2016Explorer
UGH! I just checked the fill valve and it was slightly open so I closed and opened it a couple of times, then put the pump back on and ran the faucets. It didn't change the pressure.
The mechanic did all that (checking the flow from the tank to the pump, blowing out the line into the tank to be sure it was unobstructed, tested the water pressure from the pump {the new one} and everything was fine.) I would have to take the entire bed platform off again to do those tests again. I will try other things before doing that.
In the meantime, I will keep looking for a filter. Do all RV's have a fresh water filter? Where are they located? I have no kinked water lines that I can see. I've looked closely everywhere.
