Gene_in_NE
Oct 14, 2016Explorer III
That is a lot of weight to carry behind the rear axle. The carrier will weigh as well. You might be adding close to 1,000 lbs to the rear axle. You might want to measure how far behind the rear axle the middle of the Reflex will be. It will lift most of that weight off the front axle (see-saw effect).
38,782 PostsLatest Activity: Jan 05, 2026
