RV particulars:
Driveline (Engine, Transmission): Cummins 5.9, Allison 4 spd
Miles:58,000
Year:1993
Break Down Description: (You can add any description of the problem here that you think would help others in understanding the situation and problem.)
Symptoms: Engine wouldn't start after overnight stay
Effect: No start condition
Cause: Mis-adjusted shift linkage
Outcome: started normally when shifter moved to neutral position. Readjusted linkage after reaching destination. Problem solved.
wile e
I have exact same setup('93)/Cummins 5.9/Allison 4-spd) and ran into the exact same problem. This had happened while I was tying up the island at busy gas station. I was losing popularity quick! Luckily, I had experienced this problem before with a beat up Oldsmobile in high school and knew what the problem was. It was still un-nerving.
I now push the stick into FIRMLY into Park so that the neutral saftey switch doesn't prevent the engine from starting.
