Badeye, Thanks for starting this thread. I think we could write a book on breakdowns the last 2 1/2 years including failed slidout and tire blow out but will just recap two major ones.
1. 260 Cummins 5.9 engine Spartan Summit Chassis
Allison five speed
10100 miles
2001 Travel Supreme
Sympton: temp gauge starting increasing when we were leaving early one morning from traveling in the mountains. Engine shut down. Re-started and same thing happened. Finally started third time and with a highway patrol escort got one mile to safe place to park before shut off again. Saturday late we finally got a tow truck recomeded by Cummins and towed us 30 miles across mountain to Spartan Chassis Approved repair facility. A word of caution here, be sure the tow company has a vehicle that tows motor homes!
Cause: It took Repair shop one month to determine it was a broken serpintine belt! They replaced it and Cummins recomended we take to their facility and have checked out and they determined it was from a defective idler which they replaced. I carry a spare serpintine belt now.
2. Same motor home with 21,350 miles.
Sympton: While taking pleasure ride with mother in law we smelled diesel fuel. We were near an exit and pulled over. Looked underneath and diesel fuel gusshing out. Shut engine off and tried to locat a Cummins or Spartan Repair shop late on Sunday. You guessed it , no luck and cell phone about to go dead. Luck had it we located a RV technican that services the busses for Clemson University.
Cause. One of the fuel lines had worked loose and was almost impossiable to get to. Finally got tightend enough to get to his shop and spend most of eveining trying to fix. Fixed to where we could get on highway. Called Cummins first thing next day and took to their faciliy where they did a through job tighting all lines and steam cleaning engine. You should have smelt the diesel. Everything fine now.
Tried to keep these descriptions to the minimum, just the high lights of the story and to advise if you have a problem withCummins/Spartan look for Cummins first because my experience with Spartans auth repair facility have not been good.
