Bought used, August 15,2003, with 10900 mi.
Complete ignition failure....
Result: Ignition Switch and burnt wires @ 11911 mi.
Spongey brake pedal....
Result: Air in Brake lines bled @ 11911 mi.
Brake Pedal to the floor....
Result: Master cylinder bad @ 12000 mi.
Floor heater will not shut off while driving....12000 mi.
Result: Undetermined as of yet, Not a Workhorse problem and have to take it another service facility. Repaired myself.
Remedy: Replace 3 position control switch on dash.
New problem found: 12-28-03
Front end sway (leaning away in turns)....12400 mi.
Result: Nuts and bolts missing from swaybar mount as well as crossmember plate loose.
Remedy: Replaced Missing Hardware myself.
