RV particulars: P30.
Break Down Description: Low gear only. Would not shift up.
Symptoms:
Effect:
Cause: Nylon governor drive gear on TH400 trans had teeth worn off. After second occurance used a brake cyl hone in bore of trans case to prevent apparent binding of governor.
Outcome: No reoccurances.
RV particulars: P30
Break Down description: Low power, some intake popping, flames and loud bangs out exhaust. Kept getting worse. Finally stopped running.
Cause: Spark looked a little too orange, so replaced HEI coil. Ran like new. Coil had been replaced by previous owner with an apparent no-name part.
