I had and Interesting situation that could have cost me BIG bucks except for the honesty of a good mechanic that wanted to go home.
RV particulars: 1988 Fleetwood Limited
Driveline (Ford 460 Engine (yes, it has a CARB), C6 Transmission) on a John Deere chassis
Miles: less than 50,000
Break Down Description: Quick Trip - New Orleans to San Diego (HA!) Fill-up the gas tank on the way out of Louisiana (OK, I was trying to save a bit of change and use the cheap stuff at a station right outside of the refinery) Hot to Trot!
Symptoms: Got about 300 miles into texas and started to loose power
Effect: Slowing down and even dying on the highway - kept going by pumping the floor pedal several times - over and over to get to the next town - Late in the evening (8PM). Crawled into a repair shop just closing for the night - explained I needed to get to SD quick. Mechanic listened to my sad tale and said 'If you are here in the morning I'll fix it and charge you plenty - but if you want to go across the street to the parts store and get a fuel filter and put it in yourself, you can be on your way in less than an hour'.
Cause: Fuel Starvation due to gunk cloging the primary fuel filter at the tank - most likely from the cheap fuel
Outcome: He was right - but back then I looked sort of hopeless and asked 'Fuel filter - where it is and what does it look like'? Now, I have all the owner, technical and parts manuals for the chassis, drive train and coach. And the tools to fix most minor problems if they arise. Fuel Filters? Two in the kit - plus spare belts (4 different-no two alike), and about 60 lbs of other spares I hope I never have to use - but have used several times!! There are many things I can not (or due to my ignorance or intelligence will not) do, but it pains me to pay big bucks to do the simple / minor things.
