RV Fleetwood Discovery
330 Cat, Allison 6Speed
Miles:6,000
Year:2003
Break Down Description: Loss of Port side Rear inner tire.
Effect:Need to replace tire.
Outcome: Repaired by TA Truckstop Albuquerque, NM
Being a new RV'er, I failed to check my tire pressures as I should have, the Port side outer must have been low pressure, causing the innner to wear prematurely, after the tire wore down to the belt, the outer then started to handle the gaff wearing down to half tread as well.
Spent the night in WalMart (Saturday) and went to TA in the AM. I had TA remove the fronts and use them to replace the rears and bought two new fronts.
You live and learn, I now check my tires like a fiend every chance I get. Every morning, every fuel stop and every other chance I get.
I am even thinking of getting a tire pressure monitoring system.
