RV particulars:40 ft 2001 NewMar Dutch Star on Freightliner Chassis
Driveline (Engine, Transmission):Cat 3126B engine Allison MH 3000
Miles: New to 40000
Year: 2001
Symptoms: Driving to Alaska on maiden voyage and got to Bismark ND. (about 2000 mi. on OD) and speedometer, then air, then tach. quit or go crazy.
Effect:
Cause: Needed to replaced ECU (Electronic Control Unit)
Outcome: Fixed problem although problem recurred again in Black Hills following year. Same resolution.
No further problems and now have 45,000 miles (prox).
I mention this because this is apparently a regular occurance with Freightliner/Cat. Not sure whose fault, but I sure wouldn't doubt that placing the ECU next to the engine and its heat might not be partly to blame.
Anyway, any other details of this sort would be greatly appreciated. As well as dates. This thread might help improve the breed.
Thanks to you Badeye and all who contribute
Bob Manchik
