2001 Monaco Diplomat
Driveline: Cummins 8.3L ISC 330HP
Miles: 22,540
Year: 2001
Break Down Description: No AC power to front TV, satelite systems and refrigerator (Norcold 1200 LRIM) All other AC powered systems were working
Effect: Had to run Regrigerator on DC or LP
Cause: Tripped GFI outlet in bathroom
Outcome: Reset GFI and everything worked perfectly, never happened again.
We had just set up the coach at a campground, Goliad St Park in Goliad, Tx. had AC on, radio was playing, Microwave worked, etc, when I started to try to get refrigerator to work on AC. Indicated 'No AC', then I noticed the Satelite system was not powered up and there was no front TV working. Caled the dealership after looking through the manual for 30 minutes, and checking all the breakers and fuses. Nothing tripped or blown.
The GFI was installed to protect the AC outlets and the people in the coach, however, it was also hooked to the outlet in the outside panel of the refrigerator where there is a 110V outlet to plug the refrigerator in for AC power. That would protect a person outside. Great Idea and great safety, they just should have covered it in the manual.
