Freightliner issue. We lost our volt, water & temp. gauges along with our speedometer & tachometer while driveing down I-680. In addition, the transmission stayed in 2nd gear. We were towed to Freighliner in Omaha & when we got there everything worked fine. After checking some thngs they did not find anything wrong. We left and made it home with out further incident. We called Freightliner in SC who authorized some parts replacement that was done at their Grand Rapids, MI. shop.
4 days later the same problem occurred outside KC, MO & after waiting 1 wk to get into Freightliner's OASIS dealer in KC they did find some loose wires in a harness. We left KC and in less than 100 miles the problem occured again!! Our coach is currently at Freightliner in Columbia, MO. where they will try to get to it by next Monday, July 18. All of this occurred in the last 30 days. We are new to this forum & are wondering if anyone else has had these type of problems? If so what was the solution? Also, can anyone suggest what we can do to get Freitliner's attetion so they will do more than tell us to have it towed to the next service center & they will look at it? Any help or suggestions are appreciated. Our coach is still under warrenty.
