PrairieGirl wrote:
2003 Discovery 330 Cat Allison tranny
Our leveling jacks have recently developed a mind of their own. Sometimes they work, sometimes not. I have discovered that going through the gears (on the touchpad) I can eventually get them to extend or retract. Seems their is something NOT connecting in the neutral switch. Does anybody have any info on this kind of failure?
Ray in Oklahoma
Hi Ray, this type of problem usually is a LOW VOLTAGE problem. This in turn is often cause by a POOR Ground. Best bet is the clean the ground on the pump. Also check 12V conections. Use "corrosion block" liquid to keep the current flowing.. Jack
