RV particulars: 1994 Winnebago Brave on P30 Chassis
Driveline (Engine, Transmission): Chevy, Chevy
Miles:~35K
Year:2000
Break Down Description: How is this different from Symptons?
Symptoms:Transmission shifted down to 2nd gear and stayed there.
Effect:Limped to nearest exit on interstate.
Cause:Shift transducer needed replacing.
Outcome:After transmission repair ran normally.
RV particulars:1994 Winnebago Brave on P30 Chassis
Driveline (Engine, Transmission):Chevy, Chevy
Miles:~38k
Year:2000
Break Down Description: Driving near Mt. Rushmore, going down a hill and engine cut off. Pulled over to a pullout and parked.
Symptoms:Engine just stopped running and would not restart.
Effect:Luckily there was a convenient pullout and we werent' going very fast. If happened 1/4 mile later we would have been on much steeper decline and could have been a bad day.
Cause:After being towed to Rapid City chevrolet dealer and much trouble shooting, the mechanic found that a wiring bundle which was routed over the intake tube for the air cond. compressor had an over wrap that gaped open. A wire inside had the insulation rubbed off and exposed wire shorted to the a/c compressor intake tube.
Outcome:Re-insulated the wire, fixed the over wrap and MH ran like new.
