Badeye...super Idea!!02 Holiday Rambler Endeavor 330 Cummins ISC 3000MH 6 speed Allison,15000 Miles. After fueling drove home and fortunately while in front of my house.The Check-trans light came on and the touch-plate shifter was not lighted. Unit would not shift into reverse,or anything!!! shut it off while in drive. Could not get it started afterwards. Spent 4 days trying to find someone that had a stinger long enough to reach the front axle,(another story). Had it towed to authorized Allison rep and learned that the ECU ( electronic control unit) the "brains" of the transmission was electrically burned up and had shorted out. Allison explains, sometimes "IT" happens. No charge,under warranty @ Allison and finally Good Sam decided to pick up the tow tab after 4 days of them trying to locate someone that knew how to tow a 38' diesel pusher. Hoping "IT" doesn't happen too often, cause we're leaving for Alaska this summer.
