January 2006
Fifty miles from home in a class c, A Flat
200 miles from home A Blowout
250 miles from home Fuel Filter Failure.
Took 6 days to go 500 miles.
June 2006
Engine timing sensor failed. Power Steering, warning flashers failed. An RV dealer (reputable?) improperly installed a controller for a tow dolly. Positive wired to the solenoid, negative to the frame. Can't prove it caused the failures, Go Figure. OBTW the RV dealer is out of Panama City, Florida. At first he agreed to reimburse for the full labor to fix the problem, then agreed to 2 hours labor reimbursement. However, after he talked to the tech, the tech said he did not wire it improperly and someone changed the wiring during the 1200 miles I had travelled. Makes since to me, I stopped at a Texas Rest area to use WIFI, got bored went out and changed the wiring. Will Never See a Dime. Will Carefully refer customers to him every opportunity I have. It is my sincere desire that his 14 year business thrives. Or, maybe he can retire buy a MH and have his Tech install a controller on it.
Not bad after 33 years of minor RV problems, with one prior fuel filter failure in 2004.
