RV particulars: 2007 Country Coach Tribute
Driveline (Engine, Transmission): Cat C9 (400HP), Allison 3000
Miles: 4,339
Year: November 22, 2006
Break Down Description: Coolant hose from engine to trans cooler chafed through, causing loss of all engine coolant
Symptoms: Engine warning, then engine shutdown lamp.
Effect:Unable to drive vehicle further (the electronic controls really work)
Cause:Chafed hose allowed all engine coolant to be pumped out of the cooling system.
Outcome: Warranty repair. Coach was towed to local CAT dealer where the hose was replaced, the tranny cooler mounting bracked was ground for clearance, and a broken radiator mount was replaced.
