RV particulars: Tiffin Phaeton
Driveline (Engine, Transmission): 350 C7, Alison
Miles: 4,000
Year: 2007 (less than 5 months old)
Break Down Description:
Symptoms: bottom of pass slide grinding across tile floor
Effect: can barely open slide
Cause: came from factory like this
Outcome: still being worked on
Symptom: Engine check light and protect light came on
Effect: engine shut down
Cause: Caterpillar does not know
Outcome: Cat told me to shut off engine and restart and OK to drive
Symptom: Extremely loud brake squeal on right front
Effect: pulls to right
Cause: out of round brake drum and.....
Outcome: Freightliner still does not have an answer
Symptom: Bunched up fabric covering over driver's slide out
Effect: slide will not retract fully
Cause: improper installation at tiffin factory
Outcome: still in shop
Symptom: Water leak behind connection panel
Effect: fills bay with water
Cause: improper installation of hoses at tiffin factory
Outcome: still in the shop
I won't bore you with the smaller problems. Thanks for the forum.
