campingshadow wrote:
RV particulars: 2002 Georgie Boy Cruise Master
Driveline (Engine, Transmission): W22 w/ Alison 8.1
Miles: 8,000
Year: 2003
Break Down Description: Key will not turn in ignition, unable to shift gears while parked
Symptoms: Cannot turn key - cannot move vehicle
Effect: Total lock up of steering wheel and ignition
Cause: loose fuse
Outcome: After being towed 200 miles, fuse was reseated and all worked fine after that.
I pulled into a gas station and turned off the engine to fill the tank with gas. When I went to restart the engine, the key would not move. The gearshift lever was locked solid. The steering wheel was locked solid. Was under Warranty by Workhorse so called for repairs. They towed me 200 miles (back from where I had come from) to nearest W repair facility. Spent the night at the repair facility and next morning repairman came out and checked fuses under the hood AND under the dash by left foot. One fuse was loose (in box by foot). Pushed it in and everything worked perfectly. Resumed trip with no problems.
Very expensive fuse....tow bill alone was $1500....paid by Workhorse.
Shadow
Wow what a crazy expense for a loose fuse. Your lucky Workhorse paid the bill. Lesson I learned here is that I should know the different kind of fuses that are used on my rig and carry extra ones. I also learned that you could not turn the ignition key if the fuse was blown. I never knew there was an electricial connection for the ignition key to work. Dave P.
