We all need a good extended maintenance program for break down's and I though I had one in Good Sam. I had a air compressor go out along at the same time no flow in the air dash. So I was submitting 2 claims.
Good Sam denied both claims. They said because a seal went bad which caused the compressor to leak and seals and gaskets are not covered they will not pay for the new compressor. As I explained to them that this wasn't caused by a seal and according to the invoice it was a leak and there was a bad O-Ring which caused the break down they will not pay for this part of the claim. Almost 1200.00 dollars. After going back and forth with them they send me a check for 531.00 saying they where giving me a good jester payment. My point to them was ok if you are giving me a good jester payment which is saying I'm guilty and here is some I'm guilty money, why not paid for the whole thing.
No such luck. Next part of the claim is they won't pay for the flume because of an alignment problem and alignment in not covered in the policy. Now here is a part that worked for 7 years and broke never to work again and they called it and alignment problem which didn't even read that in the invoice. 1700.00 down the toilet.
Keep in mind that your RV is pretty much made up of seals and gasket's and including the engine so if you have a Good Sam Extended Maintenance Policy you may want to re think it.
I did find another company who will cover seals and gaskets and read all the fine print and hope they will up hold the policy on my next break down and I'm sure I will have another break down along the way.
I'm not saying all of Good Sam is bad as I had good luck with there road service in the passed but now my life time membership doesn't even feel like a friendship.
Thanks for listining and happy motoring
