2008 Hurricane 34B on Ford V-10 Chassis
35,900 miles
Problem- Chassis battery disconnect solenoid failed.
Immediate loss of all power, lights, engine, power steering and braking while on interstate highway on-ramp. Shortly after the break-down, a tractor-trialer sideswiped cargo trailer and RV, causing considerable damage to RV rear, bedroom slide and awning. Had Hurricane towed to local RV, where Thor tech support advised them to jumper around the solenoid to get me back on the road. Cut the remains of the awning off the coach. Back on the road, the coach bounced horribly due to bent rims.
Thor says they will replace the control center that houses the disconnect solenoid. Thinking seriously about jumping around the solenoid anyway. If one can fail, so can its replacement.
Luckily no loss of life. I can't imaging what could have happened if it had failed a minute or two later at interstate speeds in heavy traffic, since the failed solenoid LEFT ME WITH NO LIGHTS TO WARN ANYONE...
