Winnibago, Journey 2002, 34' Cummins ISB 275hp, Allison 2000, Freightliner Chassis.
While traveling thru Delaware in November, as I pulled up to a traffic light the engine stumbled and quit. The normal dash lights were all out, nothing associated with the chassis seemed to have power. The ignition key, and all gauges dead. After being towed off the road to a rest area, I began trying to determine the cause of the situation. First I checked the battery's both house and chassis. Both battery' banks we're showing more than 12.6 volts. Checked for loose cables or any obvious problems. Tried the auxiliary start relay to see if that would power the starter, no such luck. Checked the front automotive circuit breakers and fuzes, and the buss that powers them, no power?
Called the Freightliner 24/7 Customer Service (800) 385-4357, and described my problem. Much to my surprise the Freightliner tech was extremely knowledgeable. He walked me through the diagnostics and we determined that the culprit had to be the main chassis battery 135 Amp circuit breaker. The FL tech described in detail exactly where the breaker was located and how to bypass it to determine if it was bad. The breaker is located on the drivers side behind the rear wheel attached to a flange below the rail. Not to be confused with a similar breaker assembly on the passenger side in the same location which is for the engine intake air starting aide. The test of the breaker revealed it was ok, but in the process I noticed that one of the. Wires attached to it seemed to be loose and arked as I moved it around. Simultaneously a relay chattered and the dash powered up. I cleaned and tightened the connections, the relay held and everything powered up. Engine started ect.
The location of both of these breakers is below the rails and may be in or near the road debris stream when the vehicle is moving. It is likely that water/moisture is sprayed on these assemblies when driving in the rain. Put them on you check list. Also recommend that you carry a spare, as the are not found in local auto stores. You will have to get them from FL parts. According to FL to get going until you can replace the part, you can simply disconnect the battery and connect both circuit breaker leads together on one terminal reconnect the battery as a temporary measure without harm.
