Gypsy1 wrote:
Winnibago, Journey 2002, 34' Cummins ISB 275hp, Allison 2000, Freightliner Chassis.
Put them on you check list. Also recommend that you carry a spare, as the are not found in local auto stores. You will have to get them from FL parts. According to FL to get going until you can replace the part, you can simply disconnect the battery and connect both circuit breaker leads together on one terminal reconnect the battery as a temporary measure without harm.
Gypsy1, thanks for the really good info! However, I would like to add that before you bypass that breaker to get going, old make sure it wasn't actually doing its job correctly in the first place. Otherwise one could end up in a real world of hurt.
Jeff
