Coach: Rexhall Airbus
Driveline (Engine, Transmission): 1995 p30 chassis with 454 Engine
Miles: 42000
Year: 1996
Break Down Description: Oil pressure problem
Symptoms: Driving above 50 mph the oil pressure drops to zero.
Effect: Forced to drive slower than normal taking an extra day.
Cause: Oil pump pickup came loose from oil pump.
Outcome: Picked up the rv in San Antonio and drove to Columbia Mo. with this problem. Changed the oil en route and added an oil thickener in an attempt to boost oil pressure. In service center in Columbia had the oil pan dropped and found the oil pick up at the bottom of the pan. New oil pump and pickup and problem fixed.
