1/2 Canadian wrote:
brief response to udidwht:
One thing many coach owners neglect is chassis lube. But even those that are religious about scheduled maintenance are unfamiliar with the correct lubrication of driveshafts, as unfortunately are some service facilities.
Those **** zirks are buried into those joints as well. Shaft has to be positioned just right for lube. Using Valvoline Synthetic CV/U-joint grease. I've put ~ 1300 miles on it since the axle rebuild back in Jan. All the other grease points (front end) I hit last year ~ 5,000 miles ago.
