Look at any semi or other large truck. If they run any other tire; they will still have Michelins on the front. That's the one place you don't want a blow out.
Keep your tires topped up and you should be fine.
What gets most people is the tires "look" to be properly inflated; but an inside dual might be low or have a leak. So now they have a low tire; and the other tire is carrying all the weight. High temps on the highway; guaranteed blowout.
Anytime a long highway drive is about to be started; always check tire pressures. At the least; check the inside duals.
Whatever tires you get; report back your results.
