charliereed
Jul 14, 2013Explorer
Thanks for the timely response. As I said, I'm not tech savvy and you may well be correct. In reading the Briteview specs it led me to believe that the signal went from the antenna to the 2500, then to the wireless receiver, on to the wireless TV. What would be your recommendation on hardware (beginning with the antenna to the TV?) Again, I just don't want to run new coaxial cable into the coach if possible. Any suggestions would be greatly appreciated. It sounds as though you're knowledgeable of the configuration requirement. Thanks, Charlie
38,766 PostsLatest Activity: Jan 10, 2026
