Jacks will not go down and bedroom silde went out 6" and stopped. now it will not retract no sound of motor. Passager side slide how con I get ti back in so I can move? If I can manualy retract it OK ...
Sounds like a fuse. Check all of the fuses and circuit breakers to make sure that the motor is getting power. Did you check your owner's manual on how to manually retract the slides?
