It's not too hard to replace the plug yourself. You can get the plugs at WalMart. The ones with the handle would fit through the access hole in my power bay....not sure about yours, but I would think it should. Buy one and try it before you wire it. If it doesn't fit, then return it. If you don't feel comfortable doing the job yourself, then get an electrician to put it on for you. Doesn't have to be an RV tech, unless you just want to go that route. In either case, I would HIGHLY suggest that you don't try to just stick the blade back into the plug and into the outlet.
