bhivetravelsExplorerJul 23, 2014Broken plastic Atwood hot water heater drain plugSo a small leak turned into a complete drain. The plastic bolt on the bottom of the hot water heater was leaking. In an effort to clean the bolt and then wrap it with teflon tape and reinstall it, i...Show More
JagtechExplorerJul 23, 2014Perhaps use a heat gun to heat (melt) the plug until its soft enough to deform and remove it.
Related ContentAtwood water heater problemAtwood Electric Jacks - Replacement ElectronicsBroken Leaf SpringBroken plug ion Atwood water heaterBroken rear window
