kennyd63
May 01, 2013Explorer
Buddy Brake system ?
Hi there- Is the break buddy design to apply the toad vehicle breaks every time you apply your breaks on the MH? or this is only a break away system? Thank you all>>>
RayChez wrote:Ray the type of break buddy that I have is the vantage select.:?hershey wrote:
Its an adjustable feature. You can adjust it to applying brakes nearly every braking instance on your MH or you can adjust it as I do: It only applies on panic stops. Or anything in between.
I really only depend on mine as a stopping device in case of its breaking away from the MH.
Not sure what kind of brake buddy you have, but the brake buddy I have the only adjustment it has is for pressure applied on the brake pedal adjustment to how much pressure you want to apply according to the weight of the vehicle it is installed on. If it is a light toad naturally you do not need much pressure, but if you are towing a heavy toad, you have to increase the air pressure on the brake buddy. That is the only adjustment my brake buddy has.
