Hank85713's avatar
Hank85713
brake buddy
anyone using one of these? Just had 1 given to me but is missing the 2d alert for the tow vehicle. Is it REALLY needed or just a nice to have peace of mind thing? I do not have one for my installed one for my normal towed vehicle either but it is not a brake buddy either. Watched you tube videos but all they showed was that it is just a check to show everything is working.
How does it work? is it a pendulum system in the unit? do the alert senders/receiver need to replaced as a set or can they be replaced individually?
Thanks
  • I've had a Brake Buddy since 1998 - - and it still works great! The earlier versions never had the alert system with the sender/receiver. I get along just fine without it. I set the sensitivity so that the Brake Buddy comes on when I stop fast (short of an emergency stop) so that I know that's it's working OK. Normal easy stops do not activate it.
  • my receiver keep giving me false alerts so stopped using it. I can feel it if my 16 year old classic brake buddy engages the toad brakes.
    I also set the BB at 2 as I really only want to apply the brakes in a panic stop.
  • thanks for the replies, got an email from the manuf and the receiver is not a needed item. They did verify it is a pendulum system.
  • In answer to your question, the receiving/sending unit just plugs into the unit and the coach cigarette lighter socket. They do not have to be matched. They all run on the same frequency. If you're just missing the coach receiver and can find another one it will match the one on the unit. The system is inertia based. It's a great simple unit can be switched from vehicle to vehicle. Factory service is excellent. Mine is 8yrs old and malfunctioned, called brake buddy service, sent the unit to them they refurbished it with new air pump, power cord, reset digital read out for $75 including return postage took less than a week. Great service, saved $1400 on cost of buying a new replacement unit.
  • When I towed, I used a Brake Buddy Classic. Was very pleased with the product and the customer service. I understood the alert for the toad is a transmitter and therefore needed. IMO, I would call Brake Buddy and ask them. They are fantastic with customer service.
  • I've had the original Brake Buddy Analog Classic for 18 years and it has served me extremely well. When needing to make a sudden stop it is great to have the toad brakes helping.
    You can send the unit to Brake Buddy corporation and they will do an overhaul at a very reasonable price. Well worth it.
    Brake Buddy FAQ's
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
