eubank
Sep 23, 2018Explorer
I suspect that the motorhome you're looking at has fixed-mount cylinders, not ones that can be removed. IF so, then you have ASME cylinders, not DOT cylinders. ASME cylinders do not require recertification; DOT cylinders do. (That said, if your cylinder is in bad shape, then fillers can refuse to fill it.)
Here's a bit more propane info for you:
https://salem.wbcci.net/files/2018/06/propane-workshop.pdf
Lynn
Lynn
