Bobbo
Sep 26, 2013Explorer III
eric1514 wrote:
Typically, the converter when plugged in will not charge the chassis battery. You can install this Trik-L-Start or you can throw a charger on the battery every now and then.
Eric
+1
I did the Trik-L-Start. I went to the solenoid that connects the two batteries together when you press the button, and hooked up the source wire to the house battery side, the load wire to the chassis battery side, and the ground wire to the solenoid frame. Total amount of wire needed, about 12 inches and works like a champ.
38,766 PostsLatest Activity: Jan 10, 2026
