Hi B.B.Upch,
As little as 15 amps can burn a connector. What often happens is, in a low voltage situation, the air conditioner draws more and more amps. That causing heating--which leads to even greater amp draw.
One solution is to use highest quality connectors (not female Cameco) such as Hubble. But even those may fail.
Using "dog bone" adapters is better. Treat them with deoxit from time to time and keep them bright and shiny.
If you have an energy management system, for 15 amps limit it to 12, 30 to 24, and 50 to 40 amps.
The best solution may involve an autoformer, to boost voltage, and a load support hybrid inverter charger.
Since I started doing the last two I've not had to replace a single plug.
